smashed speedo glass
maz66
Post by maz66 »
trying to see if the limiter was in my speedo, i smashed the glass. Any ideas where i could get the glass replaced? cheers, gutted :smt012
i have one :smt003
maz66
Post by maz66 »
would you like to sell it master? i also found out that its not even restricted in the speedo. double giraffe whammy. As you can imagine im quite pissed off :smt011
You should have asked mate, if its got a limiter in the speedo it will have a wire hanging out the back of it. :(
maz66
Post by maz66 »
does it? haha bollox
oh no, perhaps i should change my sig from "before you do anything, try redex" to "before you do anything, ask zxrworld" :smt005
deviant
Post by deviant »
RobB wrote:before you do anything, ask zxrworld
and before they do anything else, they will ask if you've tried redex
RobB wrote:You should have asked mate, if its got a limiter in the speedo it will have a wire hanging out the back of it. :(
i'll check mine robB i can't remember seeing a wire?? :smt017
It should have one, cos its gotta connect to the CDI.
and so it does, so RobB do you think removing the tab will have de-restricted the bike as the tab wont send the signal to the cdi?
Removing the tab will derestrict it, yeah. Its just the rest of the electronics in the speedo that tell the CDI its there cos if you unplug it, the CDI will know, so it needs the rest of the electronics in there to say its still connected. But im starting to wonder if the 10k rev limit that pops up from people every now and then is just an unplugged clock so the CDI kicks in with a 10K rev limit, and thats probably why a UK CDI will work in terms of derestricting. Like i said, i doubt derestricting is as easy as just unplugging the clock.
But a derestrictor box is just a bunch of electronics to say that theres something is there so the 10k rev limit doesnt kick in. I did try to take a derestrictor box apart once but it was immersed in black sealant which sets hard so you couldnt get to anything let alone see what is was made up of. When i finish uni, im gonna take a proper look at the speedo i took apart see if i can make some sense of the circuit thats in there. Cos it could just be a replica of whats in the back of the clock minus the tag.
If you look at this pic of mine:
http://w1.bikepics.com/pics/2006/06/06/ ... 9-full.jpg
you can see that litle circuit board attatched to the side, all a derestrictor is, is a box that looks like that circuit board to the CDI, and fools it into thinking the clock is still connected, hence derestricting your bike.
Speedy
Post by Speedy »
I made my own, just put the circuit board in a little hobby box from Maplin then sealed it all up (but I was fitting a UK MPH clock at the time too, so needed the circuit still the be in place)
Re: smashed speedo glass
maz66 wrote:trying to see if the limiter was in my speedo, i smashed the glass. Any ideas where i could get the glass replaced? cheers, gutted :smt012
do you still need the speedo glass mate?
