Can you be restricted on top speed but not acceleration????
- Head-Down
- My Bike: ZXR400 L1
im not sure if my bike restricted. the bike still gets about 55mph in first and about 85mph in second. the accelerations not to bad but once the bike gets to abou 110mph it creeps up realy slowly, could someone help! is it possible to restrict top speed but not acceleration. any help would be great.
Ride hard or die Tryin'
- deviant
- My Bike: ZXR400 L3
import bikes are restricted in the speedo to about 110. you can buy a little box of tricks that plugs into the back of the speedo.
do a search on the forum for "restrictor" or similar and you should find a load of info.
- Xphyral
stuw00d
do you mean 33bhp restricted? if its the standard import limiter then it will only restricted top speed
If its 33bhp then it will effect both
