petrol mix help asap please
simon_zxr
hi my dad managed to put the two stroke petrol mix in my zxr 400!! its a mix of 40/1 will it do any harm??? he thinks itl just oil the plugs up
Theres a few ways of doing it,easiest would be to take the tank off and turn the tap to the on position and let it drain into a container. Here's some info on taking the tank off
http://www.zxrworld.co.uk/zxr400/balancing.html
Northern ANdy
- My Bike: Unique ZXR400
then download it......simon_zxr wrote:cheers
how hard is it to drain i dont have a manual?!
it might also clog up your carbs,
run some fresh petrol though with Redex and that should clean it all out nicely! might want to check the plugs and fuel filter if its not running cleanly after you've done the redex bit
you wont have damaged the engine though whats the main thing!
