Help
Dubstar
Help
Post by Dubstar »
Is the Headlight on a l8 2001 ment to be on when the ignition is on or only once the bike is running ? Havin a few problems with the bike ignition and tryin to rule things out.
Re: Help
is it an import?
Re: Help
If its an import, the lights will come on when your engine starts. Otherwise its a uk bike which you should be able to switch it on and off as you please via the light switch.
