Hi guys,
Just recently when starting off from a stand still on my H1 I started hearing a noise almost like the kick stand bouncing of the ground as if I left it down. I got my GF to have a look as I started moving and it seems the noise is coming from the chain. She said it looks like it's getting some what stuck and that is making it shake/bounce and causing this noise.
Any ideas what would be the cause of this at all? Any info would be very much appreciated
Chain problem starting in 1st
Re: Chain problem starting in 1st
whip the front sprocket cover off mate, sounds like the front sprocket is well worn, had it on mine the sprocket was virtually rounded off.check it before you take it out again!!!!
Cront
Got the cover off and the sprocket seems to be fine. No obvious place for it to be getting stuck either
got a rear paddock stand? get the rear off the ground put it in neutral and turn the back wheel then you will see better if the chain has a tight spot or a link is seized.
Sounds like it might be a tight kink in your chain? Go round the chain and check all the links move freely
