misfire??
samuelhann
misfire??
heyyy is there any common cause of a misfire on the zxr400. wen its cold it misfires but wen its warmed up its ok. im kinda thinkin coil but they usually break dwn wen hot. i have new sparklers bt agen thts normally unda load. ne ideas ???? overfuellin etc???
mini hann
Re: misfire??
if its doing it when cold i would say its more a fuel or spark plug issue.
Re: misfire??
Cheack the HT leads mate, my XJR400 had a misfire for the 2 years that i owned it, i always put it down to the valve oil seals leaking oil as is belched white/blue smoke when it fired up. I started it one day with the tank off and saw a bright blue spark jumping from one of the leads!
kion
- My Bike: zxr400
rover220
- My Bike: zx7r p6
Re: misfire??
highly unlikey this is the problem.kion wrote:carb icing. let it warm up b4 u ride for 3 mins or so.
kion
- My Bike: zxr400
Re: misfire??
y, its winter, he says it gets better as it warms up, sounds like carb icing to me.
ride with pride
Northern ANdy
- My Bike: Unique ZXR400
Re: misfire??
but the temp hasn't been anything like cold enough for the last week. And carb icing gets worse with engine running time.
Andy
rover220
- My Bike: zx7r p6
Re: misfire??
its not just cold temps that can do it but yes, if it is carb icing it should get worse as the bike has been running longer.Northern ANdy wrote:but the temp hasn't been anything like cold enough for the last week. And carb icing gets worse with engine running time.
