Exhaust Springs
- crushedlizard
- My Bike: ZXR400 L2
Exhaust Springs
My exhaust downpipe has lost a spring on one of the pipes so sounds like a little v-twin at the moment. Any idea where I can get some new springs ie. what size they are etc?
I did a quick search on the forum but couldn't find threads.
(I'm assuming they use springs and not bolts!? If not, man am I gonna look stupid...
Sorry, if there's a really obvious answer to this.
Josh
Josh
Re: Exhaust Springs
they are bolted on mate unless you have a race system fitted then they may have springs somewhere along the pipe.
- My Bike: zx7r p6
Re: Exhaust Springs
all the springs off my micron system are missing.....any ideas where to get them from?
- crushedlizard
Re: Exhaust Springs
bugger. I thought they were bolts but saw loads of pictures of exhausts with springs. You're right though, they were all race pipes and I didn't think any different.masterofinsanity wrote:they are bolted on mate unless you have a race system fitted then they may have springs somewhere along the pipe.
Cheers, at least I know what I'm looking for now!
Any idea what size they are off the top of your head? If not don't worry, I'll hunt through the manuals.
Thanks again.
Josh
- deviant
- My Bike: ZXR400 L3
Re: Exhaust Springs
do you mean the bolts holding the downpipes to the engine (which are probably actually nuts on studs) or the bolts holding the can on?
if it's the latter I'll whip one out and measure it when I get home.
The standard downpipes/collector are welded together aren't they?
- crushedlizard
Re: Exhaust Springs
Yeah sorry, I wasn't very clear. I mean the bolts/nuts that hold the 4 individual pipes to the engine. One of them has come loose somehow.deviant wrote:do you mean the bolts holding the downpipes to the engine (which are probably actually nuts on studs) or the bolts holding the can on?
- deviant
Re: Exhaust Springs
well I'm afraid my level of motivation doesn't extend to trying to get at those to measure them. Sure someone with a bike in bits will be able to tell you.
I'd hazard a guess that they are M6 or M8 nuts though.
- crushedlizard
Re: Exhaust Springs
Haha, I don't blame you - I've failed to take a proper look and it's my bike that's in need!deviant wrote:well I'm afraid my level of motivation doesn't extend to trying to get at those to measure them. Sure someone with a bike in bits will be able to tell you.
I've got a few days off so will finally have a chance to take a proper look.
Thanks anyway.
- carsounds_dan
Re: Exhaust Springs
theyre M6, i put new stainless ones in mine but they seemed a bit shitty and couldnt get the nuts to hold on tight enough properly so changed them with 25mm M6 bolts, they went in fine and held in good, theyre stainless as well.
dan
dan
...i know, it's great
- crushedlizard
Re: Exhaust Springs
Cool, cheers mate. I'll grab a few and try them out. Else, I'll have to stop being a lazy giraffe and take one of the others out!carsounds_dan wrote:theyre M6, i put new stainless ones in mine but they seemed a bit shitty and couldnt get the nuts to hold on tight enough properly so changed them with 25mm M6 bolts, they went in fine and held in good, theyre stainless as well.
dan
The weather is dry, the sun is out and my ZXR is staring at me through my window. I need to get out there!
