warming up ur zxr400
deviant
Re: warming up ur zxr400
Post by deviant »
Scott221 wrote:
crushedlizard wrote: either sits at a gentle 1200 or screams at 4000+ Think my choke cable needs oiling...
Nah mate, its the same with all of them, they have a stupidly high revving choke. Ah well, wakes the neighbours up nicely in the mornings :D
so it seems at first, but after you've had one for a few years you develop a sort of zen mastery of the choke, allowing you to actually find the 'half choke' position.
Caz
My Bike: GSX-R600 K4
Post by Caz »
rene wrote:a good point to make about warming up...alot of poeple will keep the rev's as low as possible (ie below 3,000 rpm). At tho kids of speeds your putting the bottom end, gearbox ect under masive strain, its far better to keep the bike in higher RPM with its reving alot more freely
er.........
...............um..........
I'm interested in your reasoning behind saying this......
GSX-R600 K4
ZXR400 H2
Commuter: Gilera Runner 180SP
er.........
Its the same as when your on a push bike if you start going up a hill and put it in the lowest gear possible your going to be working VERY hard whats going to wear you out alot faster than havinging your legs turning abit faster is far easyer. Its the same for a engine.
crushedlizard
My Bike: ZXR400 L2
Post by crushedlizard »
Haha, I always assumed my cable was just gunked up. I know what you mean, I find if I move it back by a few microns, I can find a few degrees of adjustment.
Makes me wonder though; clearly Kawasaki's theory is to just let it sit at 4000. Sometimes I let it do it as 4k is pretty low when compared to it's 14.5k ceiling.
zxr_oli
My Bike: Daytona 675
Post by zxr_oli »
I found it after a couple of months :smt005
crushedlizard wrote: Haha, I always assumed my cable was just gunked up. I know what you mean, I find if I move it back by a few microns, I can find a few degrees of adjustment.
I think it's just a Kawasaki thing - at least on pre-2000 models.
I think a fully open choke on my 400 was more like 6,000 too? Even my 9 takes it to 4000 and that redlines at about 11,000rpm!
the 750 is the same in that department, you need to have it on full to get it started then quickly roll it forward to lower the rev's takes a while to get used to it but once you've done it a few times you learn were it need to be so that it dosnt stall/rev the blocks off it
rover220
My Bike: zx7r p6
Post by rover220 »
its not so much about keeping the revs off when its cold, more keeping the load off the engine.
Xphyral
Post by Xphyral »
rover220 wrote:its not so much about keeping the revs off when its cold, more keeping the load off the engine.
warming an engine up is all about keeping revs off when cold, the engine even when warm shouldnt be put under excessive load, IE trying to pull off in 4th. cold metal is brittle compared to hot metal that has expanded to it's tolerances and cold metal parts shouldnt be put through the ringer by revving the nuts off it, . Although to be quite honest for bikes made from the end of the 80's onwards it's really not an issue riding your "road" bike hard while the engines cold, metallurgy and machining got a lot better and unless you've got a very expensive tuned race engine your not going to do much more than increase the amount of wear on the engine by a small amount(2minute cold redlines not counted).
Caz
Post by Caz »
rene wrote: Its the same as when your on a push bike if you start going up a hill and put it in the lowest gear possible your going to be working VERY hard whats going to wear you out alot faster than havinging your legs turning abit faster is far easyer. Its the same for a engine.
First of all, that's not a good comparison. But, you have made a very good point about putting load on the engine. You are making the engine work harder by riding in too high a gear for the speed you are doing. But, providing you are in the correct gear for the speed you are doing, you are not putting any more strain on the engine by riding at lower revs than higher ones.
FWIW, we warm our development engines up for a considerable length of time before we start putting maximum load on the engine; gradually increasing load and speed.
I apply the same logic to my bike, make sure I am in the correct gear for the speed im doing and I keep the revs down to start off with.
That said, modern engines are that good and really don't need to be warmed up for 'normal' riding. I just cant bring myself to thrash a cold engine
the BMW manuals actually state that you should ride off as soon as you start the bike. BUT you should not put any load on the engine until it has reached operating temperature,
GSX-R600 K4
ZXR400 H2
crushedlizard
My Bike: ZXR400 L2
Caz wrote:the BMW manuals actually state that you should ride off as soon as you start the bike. BUT you should not put any load on the engine until it has reached operating temperature,
Yeah a lot of car manuals say the same. I think it's to avoid excessive idling.
Basically, don't redline it straight away and don't go clicking up through the gears putting strain on the engine.
