you probably clicked to submit your post but not realised that someone had posted as you were typing your message, you will get a note at the top of the screen and if you miss it your post wont be posted.RedexRobB wrote:Ditto! I looked at the thread and you were last to have posted but your post wasnt there, and neither was mine!Gemini wrote:i put that last night but for some reason it aint been posted. i think the head gasket has failed too
soz dude
Get a compression test done mate, only way to confirm it. It could be the stat/thermistor or whatever is it being stuck, so check those also. Basically it wouldnt piss out water unless it was pressurised or the coolant is getting exceptionally hot, which i think is the latter as yours is running hotter than normal, so that could be down to the head gasket or maybe the the stat/thermistor getting stuck closed. How many miles has the bike done? If its roughly 20k you could be looking at the gasket unfortunately.
How hot does your ZXR run?
Re: How hot does your ZXR run?
- crushedlizard
- My Bike: ZXR400 L2
Well, I just went for a 120km burn to scrub in my new tyre. Strange thing is the bike didn't get above 2 bars!? It ran fine and didn't overheat, even at traffic lights!
However, as the weather was so good, and I had such a good ride, I went out again just now and it started running hot again. Pulled over to let it cool and see if anything was coming out the overflow. Started her up again and rode home and it didn't overheat!? Temperamental son of a...
The radiator seems to work, I think it's lack of fan that screws it up. The fan is capable of cooling it down, it just comes in far too late.
Anyway, I'm just ranting. Like you say, a compression test will throw some light on the matter. I can't be bothered to do compression tests tonight though. My f%@king exhaust is blowing again too :smt013 Gonna have to fill the join with firegum again...
probably someone has posted as you were typing your messages, this then shows a notification at the top of your screen when you submit your post, you have to click submit again otherwise your post will not show up.RedexRobB wrote:Ditto! I looked at the thread and you were last to have posted but your post wasnt there, and neither was mine!Gemini wrote:i put that last night but for some reason it aint been posted. i think the head gasket has failed too
soz dude
defo wasnt that im sure, because it went straight to 'return to forum' and 'view message' page
- Jamz
- My Bike: Kawasaki ZX9-R C2
Even weirder is that they seem to have appeared again now!
so they have. i told you baz, theres something odd going on with this thread.
