rebuilding brakes...
- andyvanderpandy
- My Bike: zxr400L3
bit slow here! how do you measure the bleed nipple?! what dimension, is it the length by the diameter of the nipple or the threaded bit or the 'head'? i are confused! also i think the seals measure at 30mm if anyone can confirm this it would be most appreciated! ta
Re: rebuilding brakes...
I thought all bleed nipples were the same? No idea about the seals tho.
rover220
- My Bike: zx7r p6
definetely not on cars so pobably get differing ones on bikes too.RedexRobB wrote:I thought all bleed nipples were the same? No idea about the seals tho.
you need to measure thread pitch and diameter and go from there
bleed nipples are different and you need to get the right length. take your old one to a motor factors they should be able to match it, i just paid £1.38 for 2.
- andyvanderpandy
- My Bike: zxr400L3
well i done found out...
for future reference:
caliper seals are 34mm
bleed nipples are 7mm x 1.00mm
Northern ANdy
- My Bike: Unique ZXR400
- andyvanderpandy
- My Bike: zxr400L3
its the brake caliper piston seal, and dust seal... on an l3,
i think on the h model they are 30mm
- deviant
- My Bike: ZXR400 L3
sounds like a thread size to me...andyvanderpandy wrote: bleed nipples are 7mm x 1.00mm
thread pitch isnt it? 1mm bleed nipple is a bit thin
Northern ANdy
front or back lolandyvanderpandy wrote:its the brake caliper piston seal, and dust seal... on an l3,
Andy
- andyvanderpandy
- My Bike: zxr400L3
FRONT! ive not investigated me back caliper yet, and after this mess on the front i dont intend to either! i think theyre a 38mm boot seal on the back...on an l model... on the brake caliper... on the back...!!!Northern ANdy wrote:front or back lolandyvanderpandy wrote:its the brake caliper piston seal, and dust seal... on an l3,
