33 bhp restriction
mukka
33 bhp restriction
Post by mukka »
does anyone have any experience of restricting just using a throttle stop / limiter,
jack_zxr
My Bike: ZXR 400 L4
Re: 33 bhp restriction
Post by jack_zxr »
im not sure if/how you do it for zxr's but I would like to know too.. im trying to restrict my zxr
why would you want to?
jack_zxr
My Bike: ZXR 400 L4
Post by jack_zxr »
because ill be on a restricted licence
i meant why by a throttle stop, there are washers for the zxr400 to fit under the carbs or get a restricted CDi.
Or just pretend...
jack_zxr
My Bike: ZXR 400 L4
Post by jack_zxr »
cant find the washers anywhere and dont wana pay 235 quid from a shop for washers and fitting
deviant
Post by deviant »
The dimensions for the washers are on the forum somewhere, so if you can't find a set to buy you should be able to get a local machine shop to make you up a set to those dimensions. Should be pretty cheap.
I know of someone on another forum who had a different bike restricted using a throttle stop. Basically what you need is a bit of tube that will fit over the throttle cable inner at the carb end which you can cut to an appropriate length so it prevents the throttle opening beyond a certain point.
The tricky part is that to determine what length it is, you will need to have the bike on a dyno and do it by trial and error - longer tube gives less throttle opening and hence less power. Unless you are planning on doing a dyno run anyway it's probably cheaper to get a set of inlet restrictor washers made up.
Vard66
Post by Vard66 »
Or check on Ebay. I got my washers for .......
wait for it.......
£25.
The fitment of them wasn't too expensive either, really....
As far as my two bits about throttle stops goes, it sounds pretty shoddy. It sounds like a lot of guesswork to be viable as an easy option and also as an immediately discernable legitimate restriction method.
It also sounds a lot less fun. Who wants a throttle, that you start to wind on only to go 'oh.' when it stops. No matter how much power is under it, I reckon it's still more fun to be able to wind that damned thing all the way open.
*Edit* I suppose technically it was more like £28.50, after postage is included.
*2nd Edit* The guy I bought my washers from went by the Ebay name of 'fb893'. He may have more in the future, or it may have been a one off. Either way, I figured it can't hurt to know.
Vard.
_________________
1997 Volvo 850 R
