My zx400 88
Re: My zx400 88
Drew San wrote:Was going to comment about the KR-1 colour scheme
yeh, suits it, i'd thought of doing it before but couldnt quite vsialise how it'd work with the shape of the ZX-4.. but it works, its like KR1-S' big brother .. which ... it was :)
Drew San wrote: then I found where you got the pic's from :smt002
:smt003
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: My zx400 88
Post by Mori Man »
Did you see the other one with a start price of £2.40 shocking
That's not a typo' - it has a starting bid of two pounds and forty pence. :smt017
Re: My zx400 88
think so .. looked skanky though, and everything its missing isnt just unobtainium, its "doesntfuckinexistium"
quaidpinder
Re: My zx400 88
Post by quaidpinder »
That colour scheme is great !! ,, got the new exhaust fitted , !! but now i have an annoying stutter between 0 and 6k rpm , have just given the bike a full service ,,, but expect im going to have to remove the carbs and see what they are like !!! :smt013
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: My zx400 88
Post by Mori Man »
quaidpinder wrote:That colour scheme is great !! ,, got the new exhaust fitted , !! but now i have an annoying stutter between 0 and 6k rpm , have just given the bike a full service ,,, but expect im going to have to remove the carbs and see what they are like !!! :smt013
If you haven't jetted the carb's for the new pipe try turning your air mixture screws in a quarter turn to richen it up and start raising the the needles a notch to see if that helps.
Ideally you want to install a Dyno kit - most say you then need it Dyno'd to check the air/fuel mixture but if you follow the installation instructions there really is no need - DynoJet has already done that work ! Just an easy way for the Dyno folks to make a few quid.....
How's it sound - did you bin the db killer - if so then definitely richen the mixture as it will be too lean.
How's does it look - where are the pics :smt003
Re: My zx400 88
one of yours was it Drew ?
was assuming he'd fitted an L exhaust, they dont need any messing with the carbs to run sweet..
if its an after market one, then yeh, it probably will... and a zxr400-H airbox front will help smooth things out a bit too.. certainly did on ours.
with all that in mind, i'd lower the fuel level (increase float heigh as measured) to lean it out a bit at the bottom, ideally i guess you'd drop the needles, but as they arent adjustable its not an option, and a 1mm tweak of the float heights worked well enough on ours.
there's no dynojet kit for the ZX-4 or the zxr400-H, the one for the L makes things worse..
if you can be bothered though, getting 32mm carbs off a zxr400H should perk it up everywhere. If you intend doing this, do it now, rather than waste time tweaking the OE 30mm carbs just to take them off and start again.
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: My zx400 88
Post by Mori Man »
Carb tuning kits for ZXR's all years
http://www.kenso-bakudan.co.jp/parts/ba ... 400on.html
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: My zx400 88
Post by Mori Man »
You can look through this lot for parts still available for it.
Bito R&D make specific 32mm FCR's for it :smt007
http://www.webike.net/md/400/
Re: My zx400 88
Drew San wrote:Carb tuning kits for ZXR's all years
interesting how they have different kits for the H1 and H2, and then 2 different kits for the L's ..
000213-0062 ZXR400-H1 89 ZX400H-000001 〜006000 \25,200
000213-0072 ZXR400-H2 90 ZX400H-006001〜 \25,200
000213-0082 ZXR400-L1,L2 91-92 ZX400L-000001〜 \25,200
000213-0092 ZXR400-L3,L4,L4A,L5,L9 93-99 ZX400L-020001〜 \25,200
here, dynojet made 1 kit for all the L models, and that was it.
wonder what the differences between them are .. :smt017
quaidpinder
Re: My zx400 88
The bike did it before i fitted the new exhaust ,, although i know the owner before had stripped down the carbs and cleaned them ,,??! When refitting the ht leads I noticed that 2 of them sit higher than the others like they werent clipping onto the plugs properly but no matter what i do they wont sit down properly maybe thats the cause ,, or like zim said it may be the metal rocker cover causing an arch ? will have to take the top off and ave a look ... ,, Got some pic comming of the new pipes on there shortly !! ,, thinking of changing the calipers and discs etc to a later model as the standards are a bit wimpy also how hard is it to stick a later rear end on one ? any thoughts :smt017
Re: My zx400 88
the subframes on the zx4s are welded on aren't they? got a welder & grinder?
quaidpinder
Re: My zx400 88
Not sure will have to look ,,, Ps thanks for everyones advice and help !!! :smt003
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: My zx400 88
Post by Mori Man »
Need new photo's :please
BTW, how did you get on with your stutter?
quaidpinder
Re: My zx400 88
Well here is the bike rebuilt on frame with good log book, needs a tidy round in places cosmetically , i notice a lotof people are going with the black frame powder coated these days looks nice am tempted but since my bike is black it may be to much >?
Clocks in kmh got a cheap converter although im sure its not accurate lol
The indicators come on with the hedlamp ?
and the rear view street hawk lol
she does needsome attention still
anyhow shes still a work in progress .. ! :gamer
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: My zx400 88
Post by Mori Man »
Looking good :smt004
Keep an eye open for cheap GPz600R clocks on fleabay that will get you MPH - also look for smashed sets and just swap out the internals.
GPz 550 clock internals should also fit along with 750's.
Be better looking than that overlay :smt002
Keep the good work up,
MM! :smt001
PS. Indy's are cruise lights and that's common on Jap spec' bikes so it's a grey import.
