L model front dics diameter
- andyvanderpandy
- My Bike: zxr400L3
its hard to measure them while theyre on the bike y'know! does anyone know what diameter l model front discs are? my best guess is 310mm
with H models being 10mm smaller
also has anyone here tried puttin nissin 4 pots from a cbr600rr on zxr? i hear theyre better than the gsxr sets some people use.
Re: L model front dics diameter
i think the Ls are 320mm and H's 310mm?
- andyvanderpandy
- My Bike: zxr400L3
- andyvanderpandy
- My Bike: zxr400L3
mcn has them at 310..... but then again every other statement from them is complete lies!
http://www.motorcyclenews.com/MCN/biker ... &R=EPI-284
yeah MCN also state the rear brake is a 240mm drum
- andyvanderpandy
- My Bike: zxr400L3
i think that about sums up the accuracey of their 'journalism'masterofinsanity wrote:yeah MCN also state the rear brake is a 240mm drum
- andyvanderpandy
- My Bike: zxr400L3
is there any other way to tell from sight alone if a disc is L or H? is the carrier black only on the L, any markings etc?
I think its marked on the disc carrier, the diameter isnt it?
- andyvanderpandy
- My Bike: zxr400L3
RedexRobB wrote:I think its marked on the disc carrier, the diameter isnt it?
not that i can see...
unless its the thickness ive seen? Sure ive seen something printed on the carriers before
what you've seen robB is the min thickness of your disc. and i quote disc not dick
- jake
310 for the L , 300 for the H
ive seen some zxr's with fireblade nissin 4 pots, there probs the same as the 600.
They said they where good, did'nt ask about the fittin tho
That could well be it then!masterofinsanity wrote:what you've seen robB is the min thickness of your disc. and i quote disc not dick
- andyvanderpandy
- My Bike: zxr400L3
apparently they need drilling out for 8mm to 10mm then they fit straight on with a washer or two. ive had enough of having to take me calipers of once a month and clean the pistons etc! ive spend no end on them and theyre still goose!jake wrote:![]()
Hi, what year fireblade calipers ? please
