superman wrote:you need 1 of them expensive bike locks that cant be cut by anything. or will take a darn long time with the correct tools.
just remember DO NOT LOOSE THE KEYS lol
tie that to a lampost, then they will have to cut the post to get yer bike thus the shock of cutting the wires will leave the thief with a hairstyle like a poodle, and possibly a compensation claim lol.
If you want the best chain possible, and don't have to carry it around with you, then you should get an Almax chain (I think that's the one you mean Superman?).
The reason these are the best is simply because the links themselves are too thick to get in the jaws of even the heaviest duty bolt croppers! Every other chain will get cropped in under 10 seconds whatever fancy spiel they give you, and this can all be seen on youtube. A bloke known as Zanx has loads of vids up.
As Lewisdale says, though - if they want it they'll get hold of a plasma cutter or saw through it. The Almax chains are as good as the rest at resisting these type of attacks, but they're not infallible. They're definitely the chains to get, though.
