valve clerance
steve87
- My Bike: zxr400 h1
valve clerance
I have just checked all of my shims on my bik. max talerance for exhaust is 0.21 and mine came in at 0.23 on some. i had a rattle appar the last time i used the bike. would this be why?
Re: valve clerance
Certainly add to the over all noise of the engine - how many were loose? Not as drastic as being tight but you should have changed the shim's.
steve87
Re: valve clerance
the tightest was at .09 instead of .12, they are changed and loosest was at .23 instead of .21. so all the ones that are out are now changed. get the right sizes tomorrow so they ill all be fitted, then will give you and uodate
steve
steve
