Now i havent seen how yamaha have worked theirs, but i bet its a damn sight more technical than mine.!!!!!
Anyway ive drawn up a crude looking initial idea, and want to get your thoughts, ideas, advice and just generally your opinion!
I mean ive heard of some people putting longer inlet trumpets on the inside two cylinders so we all know that longer trumpets can help the top end, shorter ones for more grunt.
Obviously you would have to get a length that is short enough for grunt but can give good top end too.
So how about keeping the original trumpets, using a wider outer cylinder (so you dont loose volume) fix them to the carbs, once youve fabricated the plastic holder and the rest you can double the length of the trumpets, if the wires are run to the throttle housing slacken them off if theyre coming in too soon tighten them if too late.
Anyway im going to fabricate the bracket etc. Just for fun!!!!
MARCIE!
