How much movement do you have in your rear sprocket? ZXR400 L moves about 1cm up and down.
time for new cush rubbers?
Rear Sprocket Movement
- CaNsA
- My Bike: ZX6R F1
Re: Rear Sprocket Movement
you got any cush drive rubbers in there??
The readr sprocket shouldn't move at all it's bolted into place....................the rear sprocket carrier may well move a little if the cush drive rubbers are worn
- CaNsA
- My Bike: ZX6R F1
That will be that thencargo wrote:The readr sprocket shouldn't move at all it's bolted into place....................the rear sprocket carrier may well move a little if the cush drive rubbers are worn
Dont suppose anyone has one floating about thats in good nick have they? Going to The Farmyard Party / Rally in North Yorkshire on friday. Cant really afford to fork out for a new one after doing chain, sprockets and filling with new coolant.
i've got one thats might be better than yours if you wanna try it?
Do what i did, cut some old innertube to small squares and superglue it to the surfaces off the cush drive, works a charm till you get money for a proper one
- crushedlizard
- My Bike: ZXR400 L2
I thought there was meant to be some slight rotational play in a sprocket carrier? I thought that was the point of the cush rubber?
They don't exactly have to be hammered in to fit if you get what I mean... or do they?
rubber compresses, thats where the cushioning comes from
i think its about 2mm play
- crushedlizard
lol, yeah that's what I meanRedexRobB wrote:rubber compresses, thats where the cushioning comes from
