Carb problem
nathboiii
- My Bike: zxr400 L9
Carb problem
How do i get to my jets? what do i need to take the bowl off? because ive tried every screwdriver i have found and i cant get one small enough to get the back ones
and how can i get my plugs out? lol sorry i just need it done before 1 as i have college
Re: Carb problem
the bowls are a pig to get off, usually the screws chew up before they come loose. as for the plugs you need a very thin wall socket.
nathboiii
Re: Carb problem
ok ive chewed the screws up.. now what? haha
Re: Carb problem
get some heat on the screws and hit em with a hammer, make sure the screwdriver is a perfect fit then try again.Don't do what i did use a impact driver as you will damage the carb body!
Davw
Re: Carb problem
If you have chewed the screws then what I have done in the past is to use a dremel file to turn a cross head into a flat head screw and then hit it with an impact driver (heat will help also)
Re: Carb problem
that's it Dave you just go contradict me
Davw
Re: Carb problem
You must have hit it too hard
Probably dont need impact driver - if the screwdriver is a snug fit then it will turn - iirc these srews can have wd40 put in from the other end which if left long enough should do the job but that all depends on how much time you got!!
- Dazzle
- My Bike: Kawasaki ZXR400 L3
Re: Carb problem
sorry to
but where is the best place to get jets from? mine has 102's in which is too big as i only have an aftermarket can on? Thanks
Re: Carb problem
they got a good stock of jets here
Davw
Re: Carb problem
