Well after re-building the engine, replacing the gasket's and the rings. I fired up the bike.
Unfortunatly I still have exactly the same problem's as I did before. I used one of those colourtune's to see if the right mixture would help but no matter which way I turn the air screw the flame colour doesn't change.
Therefore I can assume that my problems lies after the carb's
Is it possible that there's a crack in the enginge allowing air into the cylinders and this would explain the low compression.
						Still sticky Rev's
- Miles
 - My Bike: ZXR 400 L3
Re: Still sticky Rev's
have you replaced the inlet rubbers? Airbox sitting on the carbs properly?
						- Mad Phil
 - My Bike: Hayabusa, Ducati 996SPS
You can try RTV silicon to seal the rubbers & i found that they do not run very well without the airbox, even for balancing it was far easier with the box on..
				jackdim
 - My Bike: yz490
Were all cylinders reading low comp? If not, which ones were?Miles wrote:Well after re-building the engine, replacing the gasket's and the rings. I fired up the bike.
- Mad Phil
could also be carbs out of balance holding the revs
How did you manage that one?Mad Phil wrote:even for balancing it was far easier with the box on..
- Mad Phil
sorry cant let you into that secret as yet....
awaiting patent
						awaiting patent
- Miles
cylinders 1 - 3 were 90 psi
cylinders 2 - 4 were 105 psi
Is it possible that my ignition maybe advancing?
I did the resistance test on my IC and all the readings on A negative we're out but all the rest we're fine.
Maybe from being in the water it's shorted out?
- Miles
Right got it down to my mech. today, bad news the bore's are shagged.
I am now looking for a new engine.
Anyone know where I can get one?
'falloffslowly' is your man, aka Baz - 07727 943464
You can discuss with him what you want, but he can sell you a running engine which he personally has serviced with a new head gasket, valve clearnaces and cam chain.
