Hi there, I really need help.. I've just bought a 1992 zxr 400 L model with a Denso "M" model cdi (blue sticker) and now I find a sp Cdi unit (mitsubishi with no sticker on front), so I'm trying to understand if I could mount the sp cdi unit on the bike with no problem, or if I need some other stuff (SP igniter rotor? loom?).
Could you please tell me something more about this? The only sp cdi give a really advance in performance compare to the original one? And if I would anticipate of 3-4 degree the original rotor, is possible or not without changing parts?
Thank you very very much.
Mattia (from Italy)
Need help (CDI swap)
- mark400
- My Bike: Building an original SP
Re: Need help (CDI swap)
You can only run the SP CDi with the SP loom and rotor. The SP loom also has a throttle position sensor connector ( The sp had flatslide carbs) and I don't know if the engine will run properly if the TPs circuit isn't closed.
