Still going to the service on monday, but trying to learn new stuffCos the fairing is in the way i put a long drill bit inside the front spindle and one inside the swingarm spindle, that way the centre is more or less projected out and was able to measure the distance between the two without the faring in my way.
Ive got 86cm (85.5 to a second measurement), on mine, so anything quite a bit less than that then you know its the frame/forks.
Well...i can't understand this either...I can't see how the headstock is going to get seriously knocked back / frame bend without some sort of front end impact.
