clutch basket !!!
paulg
- My Bike: zxr 400 l
clutch basket !!!
hi do belive my clutch basket is making alot of noise ....simple question if i put a new one in from cradley kawasaki will it stop the noise ?? when i pull the clutch half way in it stops thanks paul
- CaNsA
- My Bike: ZX6R F1
Re: clutch basket !!!
Its a kwak, its supposed to rattle
If it doesnt then you have a problem.
Also,
Moved from FORUM help section to CLUTCH section.
Also,
- Tirpitz
- My Bike: Kawasaki ZXR400L4
If my clutch didn't rattle I'd be straight on to Cradley's to order one that did
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Well, after Neosophist hearing my bike Thursday past - my clutch is quite
Yes, it is a KBATL too with new frictions and steels.
MM!
PS. Your clutch is buggered when it wont help you engage gears or slips a bit of noise is OK
MM!
paulg
ok moriman can u explain in laymens terms for me what parts do i need ?
There is probably nothing wrong with your clutch - mines is uncanily quitepaulg wrote:ok moriman can u explain in laymens terms for me what parts do i need ?
Some new frictions might reduce the noise depending on how worn your existing ones are - these are the clutch plates that kinda look like they have brake pad material - when you pull the clutch in your taking up slack, new ones might minimize that again and make it a little quiter.
If it aint broke , dont fix it
paulg
I find the clutch makes less noise when the carbs are well balanced. Might be a point worth noting?
oldgreyandslow
- My Bike: hornet, but want a zxr
Certainly was the case with my old fazer 600I find the clutch makes less noise when the carbs are well balanced. Might be a point worth noting?
Dolts
- Tirpitz
The manuals which have been posted up are here http://www.zxrworld.co.uk/Manuals/H%20M ... er%205.pdf and http://www.zxrworld.co.uk/Manuals/L%20M ... er%205.pdf
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
