115mph only,help please
hi,im new so hello to every1 problem i got is i have a j plate uk model zxr400l which will only do 115mph flat out,i got a dyno sheet of the person i bought here from stating 62.6horses she should be going more than 115mph read about people having 140mph out of thiers?any got any ideas ive seen those rev boosters and stuff on ebay but i think they for imports,any help greatley appreciated
- Gemini
- cloning technology
has anyone messed about with its gearing?
i think the bigger u go with the back sprocket, u get increased acceleration but lower top speed.
did the previous owner have a restricted license? just trying to establish it was restricted after its dyno test?
may have washers in the carbs u c
You dont have to take the carbs off to check if the plates are there. Take the tank and airbox off, then look under the inlet rubbers to see if theres a metal plate between the rubbers and the cylinder head.RobB wrote:The standard sproket sizes are 15 teeth on the front and 45 teeth on the rear.
It may well be restricted in terms of 33bhp becuase 115mph sounds about right for a restricted ZXR, only way to know it to take the carbs off and check.
The other way is to open the throttle wide open and look down the carbs, you should be able to see if theres a round plate with a round circle in the middle.
Now theres a man with his head screwed on! Very good point! And welcome to the forummongo wrote:
- diesel
- My Bike: Zx7r
- richie400ss
