EDIT; found my old post:
"And if you want to save a few watts, get a pair of led rear/brake bulbs from bike it. They don't require any wiring alterations like led indicators do, and they save 10w normally, and 40w saving under braking. That why your main beams dim a little when you brake - your two brake bulbs run at 21w each! they're 21/5w, the led ones are <1w. think they're only a few quid. take 2 mins to fit. did mine a few days ago, work wonderfully.
http://www.bikeit.co.uk/bikeit2011/index.html
go to page 150-151, item number LEDBLB01 (red - the white ones make you look pink!)"
on the subject of battery power, one thing to note is that these lil' beauties have very small batteries, and it doesn't take much of a drop in charge for them to be unable to spark when turning the engine. So if you do run out of fuel or such like, don't keep cranking it, or you might have a flat battery to add to your woes!
Love the black paint scheme too, mine's black and purple!
and wheel tape isn't for gheys and girls...
I've got pink wheel tape! And pink allen bolts on the filler cap... and the original number plate had the legend "my other toy has batteries"...
ok, so maybe the last owner was gay or a girl, but that isn't the point!
