newer shock on h model
- zxr400rider
- My Bike: zxr400 h1
what other model shocks will fit a h model, ive searched briefly on here and read bout gsxr shocks on an L but theres no mention of h, while im doing the single seat i thought id replace the shock at same time ( the boss letting me spend money on the bike at moment
) does anybody have an idea what would fit with minimal mods please
ZXR400 H1 gsxr600 srad rear shock, h2 front forks, delkevic downpipes, art end can,110 mainjets, braided brake lines, L model single seat, led rear light and LOTS of fun
Re: newer shock on h model
I fitted a GPz900R Ohlins rear shock no worries on my H
For L model shocks you need the unitrak linkage or fit spacers to the H one to make the bottom mount fit.
- zxr400rider
i was thinking more the gsxr shock, seen it been done here on L's just wondered if its possible on the h and worth it or not
ZX4R-F3
- My Bike: 1988 ZX400-F3
I fitted a 2002 636 shock on my H drilled the bushes out (take your time so you don't melt the rubbers) to 14mm, cut the brace out of the subframe and weld a new brace in a couple of inches back. Also have to swap the 636 spring for the 400 as the 636 is wider and rubs the swingarm
http://i1225.photobucket.com/albums/ee387/andyr71/7.jpg
Good luck.
Good luck.
[b][color=#FF0000]If your not living on the edge, then your taking up to much room.[/color][/b]
