electrical problems and running/starting problems.
- My Bike: 1992 zxr 400
Re: electrical problems and running/starting problems.
Faulty fuseboxes can cause these sort symptoms.
Assuming you have actually taken the time to go through your wiring and check for bad connections , good earth (no corrosion) , botch chops in the loom , kinks , spilt cables & shorts...... that's where I would be looking.
Yeah ok thanks, I had the same thought, just wanted opinions before taking the time to check
