For the front sprocket direction, for me the first picture below is the good direction (with shoulder outside) and the second is the bad direction (with shoulder intside), but thanks to confirm
regards,
Vince
Be carefull, because the sprocket on my pictures above are 13 teeth, not 15teeth like original sprocket, see below my other front sprockets, you can see the 15teeth and 16teeth have shoulder to ensure sit flat for retaining plate (and not 14teeth and 13teeth on my first picture)Mad Phil wrote:Yes the shoulder against the bearing.
If the other way round the retaining plate wont sit flat.
