hi ive just got myself a 89 h1 to do up but ive run into bit or a snag.
i cant figure out how to fit the oil cooler to the radiator.
in the manuels it shows a large curved rad but mines a straight one
can any one help? any pic would be good to thanks
radiator and oil cooler problem
- My Bike: suzuki sv 650
- cdstirland81
- My Bike: ZXR400H1 and proud!
Re: radiator and oil cooler problem
you should have two brackets coming down off the rad/engine mounts with tabs sticking in with nuts spot welded on you can bolt the oil cooler to, as in the right hand side of this pics:
(click to enlarge)
hope this helps!
don't take the h model manual off here as gospel, its for a h2!
(click to enlarge)
hope this helps!
ameteurs practice and train unitl they can do it, professionals practice and train until they cannot fail at it..
thanks mate.my brakets only have space for the raiator.
the onluy place i can see that it will fit is on the four tabs on the bottom of the rad juat not sure it will be strong enough to hold it
- jake
i think the H1 or zx4 does'nt have an oil cooler, just the small rad.
under the sump does it have 2 inlets for the oil cooler pipes? if not dont bother with the oil cooler.
If it does, maybee see if you can get a h2 setup?
on the h2 the oil cooler bolts straight to the rad
yeah is has the holes in the sump
im half way through making a bracket.
just waiting on bits!
