k reg zxr400 wont start backfires
				amypauljack
 - My Bike: kawasaki zxr400
hi just got a non running zxr400 on a k reg was told it ran a bit rough up until ahole in exhaust was patched up. when i turn engine over it just backfires now and again, i have added fresh fuel and there is good spark at the plugs, fuel pump works ok wot could it be the carbs i was thinking or could it be the cdi thanks paul
						- CaNsA
 - My Bike: ZX6R F1
Re: k reg zxr400 wont start backfires
drain the carbs, wait 5mins, give it a 1/3rd choke no throttle hit the starter.
let me know
						let me know
- liam7200
 - My Bike: R6
sounds like you have had this problem b4 cansa lol
									live fast, die smiling....no regrets!
take care, live a long and tedious life!!!
I choose smiling!!!
I choose smiling!!!
- CaNsA
 - My Bike: ZX6R F1
before i got the lump tuned and sorted a few niggles out i did
Also, turn the lights off if you can.
Gives the starter motor a bit more punch.
may also be fouled plugs, so may be worth whipping them out and giving them a clean and resetting the gaps
				amypauljack
drained the carbs cleaned plugs still no luck just backfiring and the odd flame from exhaust and carbs
In that case get those plugs out and clean them up. They are more then likely soaked in fuel now, so a good clean and heating with a blow torch or the hob if you have a gas one.
						- CaNsA
 - My Bike: ZX6R F1
Where are you amypauljack?
Also, might be worth askin if you can have a decent forum name, cos lets face it, thats a bit of a mission to type.
just re-read your post, you already cleaned them......
how did you do it?
						how did you do it?
				amypauljack
cleaned plugs with wire brush /emery cloth sparks good now, i was thinking could head gasket have gone and engine be losing compression has anyone had this happen or could ignition timing of moved somehow i am in lancaster thanks
