So the bike passed the MOT fine... visit to the DVLA office on Monday to get it registered.
Started it up today however and it was only firing on 3 cylinders :/ One of the plugs was the black it wasn't firing (CR9IEX Iridiums)
Had trouble before but the carbs were manky.. there perfectly shiney now.
Sooooo
It's a Jap L1 model with 90 mains...
The L supplement says pilot screws should be 1 5/8 open.
I've got them set at 2.25 at the moment (as forum / board members suggested between 2 - 2.5)
Looking at the manuals it says for the H model that its 2 - 2.5 and the L model 1 5/8ths.
Anyone else confirm this?
I've cleaned up the plugs and am going to try leaning the carbs out a bit now.
Will get it dyno'd and set up when it's all on the road just don't want it so rich its' fouling plugs.!
Blaaack plugs
Re: Blaaack plugs
yep, but . really.. just set them rich enough not to hang, and lean enough not to bog down..
and, I doubt blackened plugs is down to a fractionally rich or lean idle mix.. see how it is after its been ridden in anger n stuff ..
I've not had good experiences with the iridium plugs either btw ..
