Thermo switch
Daniel.p
- My Bike: Zxr400 93
Thermo switch
Right my thermostat isnt reading my temp is it the switch on the rad that needs replacing or is there one the engine if so where?? Thanks
Ride it like you stole it
Re: Thermo switch
the thermostat is a mechanical device and has no electricial connection.......................
Temp is measured via a probe on the rear of the cylinder head it has a single wire leading to it
The connection on the radiator is for the fan
Re: Thermo switch
What Cargo says - theres a temp sensor that goes into the thermostat housing, bung in a new one and all should be well. (Single Yellow lead on my bike)
MM!
MM!
