Hi ,my zxr 400h which hasn't been started for years won't run without the choke being pulled.
It has new plugs,stick coils and I set the pilot screws to spec on the manual,the fuel level is perfect in the carbs.
I have a carb balancer on the way but I don't think balancing is the problem,can anyone suggest what else might cause this?
Thanks .
Won't Run Without Choke??
zxr500man
- CaNsA
- My Bike: ZX6R F1
Re: Won't Run Without Choke??
Turn the idle up?
zxr500man
No it's not that but thanks anyway.
zxr500man
I took off the carbs and opened the cover for the floats,all 4 pilot jets were blocked.
So hopefully that does the trick, will try it out later.
