I have a 93 that I picked up a month or so ago as a non runner, it had been off the road for 5 years.
A wire was that badly corroded on the ignition switch plug that it had dropped off.
Sorted this, drained the petrol, cleaned & synced the carbs & cleaned up brake calipers & got it through an mot.
It would start fine, but the revs wouldn't drop quickly & I was told the mixture was too lean for the non standard can I have.
In order to get the revs to come down nicely I ended up going to 3 turns out on the pilot screws from 1 3/4.
I rode it to work yesterday & it was a bit hesistant on small throttle openings, so I guessed the screws needed winding back in a bit.
Riding home this morning, the first 4 miles were fine, then it lost the plot - had to keep the revs really high & just made it home!
I have had the plugs out this afternoon & they were very sooty, so I have obviously made it too rich & gone to 2 turns out.
It refuses to start, I get the very occasional backfire, but that is it
I am getting a spark & the plugs are getting wet, I'm at a bit of a loss!
I'm guessing that this is electrical rather then a fuelling issue.
Any ideas, please
