Bike is running sandy bike spares downpipes with stock can, de-snorkeled airbox with k&n filter. Pilot is K35, needle is N77S with 1 shim between needle and slider, currently K95 mains on all 4 carbs, pilot air screw is 3 turns out from fully in and the float bowls are set at ~12mm.
Pilot settings are spot on and the bike fuels up to ~7-8k fine, but anymore than than and it needs the choke to properly run (bike gets a bit hesitant). So if you have some spare main jets can i borrow them for a week/fortnight? I would post them back once i know which new ones i need to buy. Or if someone can assist me in making a bit more of an educated guess as to which jets to buy to start off? I can defo afford to buy 2 sets, i was thinking 98 and 100 and try them out, so all 4 carbs with 98's, then swap #2 and #3 carb for 100's, then try all 4 carbs with 100's...seems sensible to me. Once the fuelling feels fine by me ill take it for a dyno before the new can comes for christmas
Thanks.
