removing restrictors
jonnyjackson500
My Bike: zxr400
Post by jonnyjackson500 »
im just coming off of my period for needing the restrictors in, ive got a 94 zxr could anybody help as to where the restrictor will be, the restrictors comre from fi international if that helps shed some light atall.
Re: removing restrictors
the restrictors are metal plates that go between the carb inlet rubbers and the head.
you will need to remove your rear panels, seat, fuel tank, airbox, carbs and the carb rubbers to get to them.
they look like metal disks with a hole in the middle, then you want to throw them in the bin and go for a ride, note - you might need to adjust your fueling now, so first thing is to ride to a dyno place and get the bike tested, then listen to what the operator has to say and post up the chart so we can see if you need any carb work doing.
removal is reverse of installation ;)
viewtopic.php?f=55&t=6402
jonnyjackson500
My Bike: zxr400
thanks for the help guys
