h carb i.d
richyrd5
My Bike: 400h
h carb i.d
Post by richyrd5 »
Hi.taken my carbs of and cleaned them out...i have 92 mains(all 4)and,I think,dj needles(no markings and waisted towards the bottom)with clips on 3rd from top(half way) shims under each one...do you think I need bigger mains??.was going to try 98 or 100..any pointers welcome smiler....also how many turns on the pilot screws...they were on 1-n half out....out to richen right??
Dominik
My Bike: Zxr 400 L3
Re: h carb i.d
Post by Dominik »
Pilot screw out to richen the mixture, that´s right! H-Model has 2 1/4 out but with dj needle i would try only 2 turns out.
Oem Needles (marked with N77 or so) don´t have clip-positions so you´ll probably have aftermarket ones...
I wouldn´t change the main jet if there´s no problem with the current one... Can´t tell for the H-Model but the L has 95 mains stock in Germany and with K&N Filter, modded airbox and open endcan you could use 100... However your needle will change the circumstances so I can´t recommend you anything but "never change a running system"
Zxr 400 SL - 130kg
Re: h carb i.d
Dominik wrote:Pilot screw out to richen the mixture, that´s right! H-Model has 2 1/4 out but with dj needle i would try only 2 turns out.
spot on, take it to a dyno place, get an air/fuel printout and post it up here, this will tell you if you are lean/rich anywhere in your current setup, that will tell you where/if its possible to alter your mix.
richyrd5
My Bike: 400h
Re: h carb i.d
Post by richyrd5 »
Cheers for reply dominik..i have a non modded airbox and dj needles with k+n filter..aftermarket exhaust..i read on here that standard jetting can restrict the motor so wanted to upjet anyway though as its running exhaust/filter..is it best to take snorkel off??.it had been standing for 5 months in the rain and shite so carbs were blocked and filled with water!!.all sorted and clean now so will put back on and see what it runs like.(when I've done valve clearances!)so 2 turns out on pilots yes?..
richyrd5
My Bike: 400h
Re: h carb i.d
Post by richyrd5 »
Yep as soon as its running I will dyno it banner.. winks
richyrd5
My Bike: 400h
Re: h carb i.d
Post by richyrd5 »
just a quick ask,,how does the pilot/mixture screw go together?screw/spring/washer/o-ring....or screw/spring/o-ring/washer?cheers
Re: h carb i.d
richyrd5
My Bike: 400h
Re: h carb i.d
Post by richyrd5 »
smiler thanks again ban!!
