Carbs just won't balance
Miles
My Bike: ZXR 400 L3
Post by Miles »
So close to finally finishing my 7 year (yikes) build and today I spent hours trying to get the carbs to balance.
The carbs were sonic cleaned and rebuilt to standard with all new seals and correct float heights. New o-rings under the carb rubbers
But try as I might she won't balance and as usual the revs are hanging all over the place. When she will idle it's only for a minute or so before she cuts out.
Anyone point me in the right direction? I'm determined not to miss another summers riding
Dominik
My Bike: Zxr 400 L3
Re: Carbs just won't balance
Post by Dominik »
At which rpm are you trying to balance it?
Sounds like false setted pilot screw to me if everything else is alright...
Zxr 400 SL - 130kg
Miles
My Bike: ZXR 400 L3
Post by Miles »
Trying to balance it at idle but she won't idle for long as she either cuts out or the revs jump about.
I already replaced the o-rings under the carb rubbers but I've order new rubbers now as well so I'll check the carbs over again when I fit them
Flatcap
My Bike: ZXR 400 L4
Post by Flatcap »
Cant help much Miles but feel yer pain vsad I ended up buying a set from a 16,000 miler & seems to be sorted now
Miles
My Bike: ZXR 400 L3
Post by Miles »
I know it's a bloody nightmare!
I have a second set, il try cleaning them and put them on as see what happens
