burning oil
hollingsbee#54
burning oil
My bike appears to be burning oil as the level keeps going down and I have been told that it occasionally blows a bit of blue smoke from the exhaust. Does anyone know where the problem could be?
Rob Hollingsbee Superbike 400
could be valve seals or piston rings? i'm no engineer but i think for blue smoke thats the common faults.
sloweracing
hollingsbee#54
sloweracing
Sorry we dont use them as we only run the standard kawasaki pistons 0.5 for reliabilty
The J.E come with down falls most of the 400 riders are using standard but the 1mm pistons are not that clever we bought a set and sold them can get some if you want some
Sorry Rob
Ring the tuner who bored it out might give you the answer mate on why its passsing oil
Good luck Rob see you in France
Email if you need help with the engine Rebore etc or new 1mm pistons
Sorry Rob
hollingsbee#54
Caz
- My Bike: GSX-R600 K4
there are two main places that can allow oil into the combustion chamber - valve seals and piston rings.
Some bikes use oil, you havent given us an indication of how much the bike is using though. My boyfriends old bike used to burn some oil, and regularly required topping up in between oil changes. OTOH, neither my gixxer or my ZXR burn any oil.
Possibly a silly question - but you haven't over filled it?
You said that the bike occasionally gives a small puff of blue smoke? That really shouldnt be too much to worry about. However, if you are getting huge plumes of blue smoke whilst changing gears, or if there is a constant smell of oil whilst riding behind the bike, then you have a problem that needs to be sorted. Which will probably involve stripping the engine and inspecting the individual components to determine the problem.
GSX-R600 K4
ZXR400 H2
Commuter: Gilera Runner 180SP
ZXR400 H2
hollingsbee#54
its noting major, I just got pulled over by the marshalls after a race at the weekend and they said they could see a small amount of blue smoke when I was off the gas comming into surtees at brands. I checked the oil level and it was low so i topped it up, but by the end of the weekend it was looking fairly low again.
sloweracing
Rob i wouldnt worry if she blows she blows
I would think its either not run in yet and is still passing oil which mine did for a few meetings now has stopped i was drinking 200mil over a weekend form friday to sunday has now stopped it has stopped now
Or you have glazed the bores i would go to France then see what happens and just keep a eye on the levels and performance side of things
Good luck see you there mate
Dont panic its a race bike must have a few spare engines
hollingsbee#54
