FULL MICRON SYSTEM K & N DYNOJET fluffy between 1-4000 r
Ford
Post by Ford »
Hey ive had a Full micron exhaust system fitted a K & N filter fitted and a dynojet stage 1 kit fitted.The bikes fine above 4,000 revs but before theres no go whatsoever between 1500-4000rpm does it just need carbs balancing or is it just a kwaka 400 thing? cheers Phil.
RstredS
Post by RstredS »
the 400's have sod all power before 7-10k revs really, especially not 1500, thats fukin idle!
nah seriously, u have to slip teh clutch a bit to get it going to about 4, then let it go!
with all those mods have you had it setup properly??
Ford
Post by Ford »
yeah i think when the dynojet kit was fitted the guy who fitted it didnt set carbs up for bottom end like when your goin along lets say your under 4k and you twist throttle back it blips doesnt do anything then when it hits 4grand it just starts pickin up properly i think im gonna get it in at local dynojet centre from where i live get em to set carbs up and do a dynorun should be kickin out 60-65hp :smt001
