Hello all
Does anyone have a how to change a clutch write up?
ive seen this for the torque settings
so happy with that just need a quick guide what to do and what order
thank you in advance
alex
Changing clutch? how to
have you looked at the H manual as well?? you need to use both manuals if you have a L model.
ok reading on it
remove cover
undo four bolts with springs etc
then im guessing u slide the friction plates and clutch plates out?
but according to the manual u it says to remove the clutch nut which looks like to me what holds the clutch basket in place
why do i have to remove that? if im just swoping the plates?
remove cover
as you say remove cover, and springs then remove plates, note which way the steel plates go, apparently there is a difference, 20 minute job mate. forget the centre nut,not needed.
