Valve Guide Removal
Wagman2000
My Bike: ZXR 400 L9
Valve Guide Removal
Post by Wagman2000 »
Due to slightly bent Valves I’ve damaged the valve guide removing it (Part of a bigger problem. I have a new top end coming but I thought I could save as much of this one as I can). I now need to remove the valve guide. Looking at the drawings there’s a clip holding the guide in place but I can’t seem to see it. Does anyone know a procedure for removing one of these and the clip? I had a tool made up at work that fits nicely but I don’t want to attempt battering it out yet if there’s a clip holding it in.
Any advice would be appreciated.
Miles
My Bike: ZXR 400 L3
Re: Valve Guide Removal
Post by Miles »
Is the method for removing the valve guide not in the workshop manual?
Wagman2000
My Bike: ZXR 400 L9
It just says heat it up and bop it out with an arbour. There definitely seems to be a clip or something in the manual though...
Wagman2000
My Bike: ZXR 400 L9
Part number for the clip 92033-1247
ChowderV4
My Bike: Zxr400L racer
Post by ChowderV4 »
The clip is the retainer to stop you bashing the guide all the way through when installing.
I had to remove one, I put the head in the over for 10 mins at 180 :pmsl
Made a aly drift that fit inside the guided and had a top hat edge to strike the guide, a few swift hits and it came. Out nice and easy
