Bike barely pulls after 8K rpm (no matter the gear)
After 8K rpm the throttle has a "sweet spot" there it pulls a little bit but not much. More throttle after this it pulls less, same goes for less throttle.
Things I will test:
Will it pull beyond 8K rpm with a bit of choke added? (later today)
Will cleaning and adjusting the carbs help? (this weekend)
Will a new air filter help?
Some additional info on the bike:
It has been restricted to 25kW? Should be 25kW according to the license but I remember the seller stated 35kW. (will hopefully be able to see this weekend as I will be taking of the carbs)
Bike doesn't like starting, needs choke and a minute or 2 to warm up before it keeps a high enough idle (about 1350rpm), when it is warm it needs a bit of throttle to start
Anything I am forgetting to check? Or other general related advice?
Also does someone know the air filter dimensions? I couldn't find online and plan on replacing the current one as it is of unknown age and not very clean, haven't been able to see it's brand either.
Thanks to anyone taking the time to read this and perhaps give some advice
