Help needed asap
tommyb
Help needed asap
Post by tommyb »
Right took bike apart today for a clean, then noticed that the HT on cyl1 wasnt connected for some derranged reason. HT lead was split so got a new one, fitted it, went to start bike, and nothing.Wouldnt start for toad. After about 10mins of solid trying with the choke it eventually fired up, but ran unbelievably toad. The revs shot upto 4k, and slowly very slowly dropped to 1.5k then it cut out, started it again and the revs started dancing all over the place. When the bike is revved its taking a good 2/3 seconds to respond to throttle movement, and i cant seem to figure whats wrong with it. I need the bike on the road for monday for a job interview otherwise im fecked.
Cheers peeps,
#tOm
Sound slike your CDI has had it. Been a few members here had that exact same problem and im sure its the CDI thats had it. Might wanna give the battery a good charge too i beleive that can cause you similar problems.
tommyb
Post by tommyb »
got it sorted now, the end of the sparkplug that the HT lead attaches to is fecked, so the HT lead wasnt making a good connection and it kept cutting out and going onto 3cyl. Just an idle prob now, it wont idle atall, and the revs are taking a while to drop.
jhhunt
Post by jhhunt »
Glad to hear you got it sorted
Good Luck with you interview :smt002
Previous bikes> Kawasaki KH125/Honda Nsr125/ Yamaha dt125/ Yamaha dt125x
Current bikes >zxr 400 L
