just got my zxr about 2 weeks ago, and i think the headgasket has gone?
there is a leak coming from that area, and its running down to the left top engine mount, oily?
headgasket or not?
Headgasket
Not nesscessarly.
There are little holes on the front of the cylinder head that drain water or oil from the spark plug holes if the rubber seal on the cylinder head/rocker cover is leaking than oil could be running down from there.
It's a far easier job to replace that seal than a head gasket.
Do you have any loss of performance ?
Are you losing water for no obvious reason ?
Is ther oil in you water ?
Or water in your oil ?
You might even hear a blown head gasket if it was bad ?
A compression tester might give some guidance
Give the whole area a clean and start the bike and look for oil leaks ?
