Pillion Seat Stuck
- Full Licence rider
Pillion Seat Stuck
ok i have a slight problem i brought my ZXR 400 and it was delivered on sunday its all sweet so far but my brother had a look took the pillion seat off and then put it back on but he put it on wonkey and now its stuck does anyone know a simple way to release it cos the key dont work and iv tried giving it a good pull but i dont want to bust the plastics.
Also i have just had this bike and it has no service history, what would you suggest i do with it ie should i change the oil/ air filter or send it to a mechanic for an engine service of some sort the bike is from 1993.
Thanks in anticepation
Rob.. :smt013
Rob.. :smt013
hi mate, slide your hand up the left hand side rear panel and you will feel a cable, give it a good pull and it will release the seat.been there done that! if you can't do it pop over to me and i'll sort you out. Got any pics??
cheers mate, ill give that a go over the weekend if im still scratchin my head
ill take some pictures. the seat is pushed down cliped in i think but i think its slid the wrong side of the mechanism the key turns when i put it in but no joy when i pull it. Cheers for the offer thoe mate.
Yea cheers mate ill give that lot a go then it will have to be next month thoe cos the bike has cleaned me out at the moment, are all of those things easy to do? i know abit about engines but its different from bike to bike i guess.
isn't there a strap bolting the seat to the frame?
can't remember which bike it was now but i think when the rear seat was unlocked and removed there was a strap about 10" long from the seat to the frame to stop people nicking the seat.
says a lot for the foreigners then?
ah rite a pair of sissors would do it then hardly seems worth puttin 1 on. they would have done far better tryin to move that cable out the way abit more but it was easy for me to sort the problem out and ill not park it up alone anyway except my garage.
- deviant
- My Bike: ZXR400 L3
so they nick your seat, try to run off and pull the bike over? great move
personally I wouldn't be two worried about someone pinching it. although some thieving git in bath nicked the filler cap off my 125, and even more bizarrely replaced it with a different one.
