Exhaust Query
MonkeyBusiness
Exhaust Query
Post by MonkeyBusiness »
I saw a race-bike at the track the other day with one of these exhausts.
Now, as I can't imagine that it has much of a baffle, if at all, I was wondering what the pro's and con's of having an exhaust like this would be i.e. no end-can / no baffles?
Would it make a difference to performance, engine compression etc etc.
I really like the idea of not have a big end-can which messes with the sleek lines of the bike.
Ride it like you stole it!
deviant
Post by deviant »
my belief (and I'm sure one of the racers can give a better answer) is that open pipes give a better top end at the expense of midrange - a bit of back pressure in the system helps with the midrange (I have no idea why), but ultimately, the more free flowing it is, the more top end power it can produce. Hence a lot of modern bikes try to compromise by having valves in the exhaust which restrict the flow at low rpm but open up at high rpm.
I'd expect you'd need to change the fuelling to suit.
oh, and it will be offensively loud!
doesn't it give you faster pull off speeds too??
deviant
Post by deviant »
what do you mean?
heads gone blank, you know what i mean you twist the throttle and away you go..
deviant
Post by deviant »
the sort of thing that might be the result of better low/mid range torque?
yeah summat like that, thats why drag racers use vance and hines pipes aint it? so they get away quicker? now if only bonnie & clyde had thought of using one?
Bozzie
Post by Bozzie »
masterofinsanity wrote:doesn't it give you faster pull off speeds too??
i just use porn instead ;)
Dirty boy! Havent you got girlfriend?
diesel
My Bike: Zx7r
Post by diesel »
if he hasnt he can have mine. everyone else has :smt001
Quicker Than Yngwie
MonkeyBusiness
Well that was constructive. :smt002
Anyone else have a more solid understanding of this subject, excluding the Porn-Kings? :smt003
