bold head gasket claim!
davidmiladinovic
now this claim isn't from me. my head gasket recently blew, so naturally i set about trying to cure the problem. i came across a company called steel seal, they sell a product thats targeted at fixing blown head gaskets and cracked casings. its like a chemical metal that you mix with your coolant and at a certain temperature it sets after circulating your colling system. HAS ANYONE HEARD OF STEEL SEAL? IS IT ANY GOOD?
gubbs
- My Bike: ZZR1100C3
davidmiladinovic
hes trying to have your pants down and run off with them..
all you need to do is Skim the head, put new gasket on tighten up
Hynes manual will talk you though it, id plan a day or 2 if its your first one though
loads here mate http://search.ebay.co.uk/search/search. ... gine+hoist
- Full Licence rider
Ah cheers Baz, so if i set 150 back that should get me one with a 1 ton capacity dont need more than that do i.
do you have to put chains round your engine and that to hoist it out with these things. bit worried i might damage somethin. not that iv got any plans to do anythin till winter time anyway thoe.
Really, ah thats not so bad then, you know when i take the engine out can i just stick it on the floor an work on it from there or do i need to place it on a soft surface or somethin, i think ill strip it come winter an clean everything out.
What i advise is, get something underneath the engine so when you take out the bolts it doesnt just drop, if its got something underneath that'll take the weight. Use something like bricks. Then get someone to help you with taking the weight of the motor while removing each layer of bricks till you can finally pull the engine out to one side. Id put a carpet down, just incase, if it does drop slightly then the carpet will absorb some of the impact. Also if you need to move the engine about your not gonna scratch the bottom of the pan on concrete.
You can get stands for thr engine, its like a big board with two jacks at each end, when the engine is released you just lower the jacks and then remove the motor. they are in the manual somewhere.
Northern ANdy
- My Bike: Unique ZXR400
davidmiladinovic
gubbs
You just need a pane of glass, some wet n dry and a bit of patience.davidmiladinovic wrote:does skiming the head need to be done on a milling machine? and why skim the head, is there likely to be carbon build up or something? cheers.
Gaffer the paper to the glass, sprinkle on some soapy water and figure of eight the head until its perfectly smooth and perfectly flat accross the whole surface.
You really dont need to go mad. Few mins thats all ..
No point cleaning all the carbon off the valve seats, piston crowns etc. Its all going to re-appear soon enough and won't throw your valve clearences off all over the place for the first 2k afterward.
As for using a lift/crane ... you could I suppose.
I just use muscle, a pallete and some bricks:
http://cjgavin.com/beam/ZXR400H/
