(i know i am a thick Camel when it comes to mechanics lol
You'll have a nasty shock if you got on a british bike then!rene wrote: reason why they do it is because its a standard - its jsut were everyone expects it to be
superman wrote:an found i couldnt change up a gear without standin up on the pegs so i could leaver the gear selector.
you've probably put it back on at a different angle to where it was originally. if you pull it off again you will notice that the shaft has a load of teeth on it, and so does the clamp. obviously you can put the two together as many ways as there are teeth.superman wrote:then somehow adjust the selector lever thing so its down more cos i cant knock it up a gear..
