coolant leak
rover220
- My Bike: zx7r p6
coolant leak
hi guys, have a bit of a problem on my zxr.
its loosing coolant, after running/while running, you can see it building up between where the 2 fairings meet under dead centre of the bike. are there any common places where these leak from?
ill whip the fairngs off at the weekend and check all hose clips but ill happily recieve any advice.
cheers
mike
cheers
mike
Re: coolant leak
could be throwing it out of the expansion bottle?
rover220
- My Bike: zx7r p6
Re: coolant leak
masterofinsanity wrote:could be throwing it out of the expansion bottle?
its not coming out of the cap, no.
Re: coolant leak
i meant the overflow mate, there should be a pipe on it if not it could be blowing out and running down the inside of the fairings, have you checked all pipe fiitings and the coolant drain plug?
rover220
- My Bike: zx7r p6
Re: coolant leak
it is indeed coming out of the overflow.masterofinsanity wrote:i meant the overflow mate, there should be a pipe on it if not it could be blowing out and running down the inside of the fairings, have you checked all pipe fiitings and the coolant drain plug?
headgasket has supposedly been done so im hoping its not this, it doesnt overheat though but ive only been able to ride it 5 miles so far.
cheers
Re: coolant leak
How far has the expansion bottle been filled up? If its been filled to far that may be why its coming out. Theres markers on the bottle to indicate where the coolant level should be.
rover220
- My Bike: zx7r p6
Re: coolant leak
it was at the max when i left it, ill check tomorrow when its cooled down, if it hasnt moved i guess i overfilled it and it spat the excess out.RobB wrote:How far has the expansion bottle been filled up? If its been filled to far that may be why its coming out. Theres markers on the bottle to indicate where the coolant level should be.
rover220
- My Bike: zx7r p6
Re: coolant leak
right, water level was almost at the max so i must have overfilled it and it spat the excess out??
however, i had it idling for a while earlier and the fan showed no signs of coming on, at what position on the temp gaguge would the fan be expected to come on?
cheers
cheers
Re: coolant leak
I think its just over half way on the temp gauge.
rover220
- My Bike: zx7r p6
Re: coolant leak
mine was getting on for nearly 3/4 and still no fan.RobB wrote:I think its just over half way on the temp gauge.
wheres the temp sensor placed in the rad? ill bridge the wires here first to check this is working.
cheers
Re: coolant leak
They are located on the left hand side of the radiator i believe
rover220
- My Bike: zx7r p6
Re: coolant leak
as your sitting on the bike? i shouldnt be lazy and should just look for it myslef really lolRobB wrote:They are located on the left hand side of the radiator i believe
cheers
Re: coolant leak
As your sitting on the bike yeah
Its kinds obvious where it is if the panels are off, in fact i believe you can easily get to them with the panels on as i recall having to always reconnect mine when they came off.
rover220
- My Bike: zx7r p6
