Right then fellas. Has anyone got a write up on how change the oil on the bike. New bike person so havent even had a look at it, just thought id better ask on if theres a percific way you do it all.
Need to tackle it tommorow in the garage but i havent a clue
Oil Change
tng21
- My Bike: zxr 400 h1
Re: Oil Change
pretty easy enough mate, i'm sure its been covered before and its in the manuals, stick a washing up bowl under the sump, unscrew the sump bolt and drain the oil, take off the oil filler cap to allow the air to circulate so the oil drains quicker, remove oil filter, wipe new oil around the seal of the new filter and screw on hand tight, replace sump plug and refill to max level.run the bike for a bit to allow the oil to fill the nooks and crannies then top up if necessary.
